Topic: FF UC and USB3
I read a number of discussions on other forums about whether the Fireface UC could benefit from the arrival of USB3 interfaces. To me, there are two different aspects involved in this.
1) A new driver is needed, else the FF UC is probably seen as a USB2 device by the USB3 port which can also act as a USB2 one
2) And most likely some hardware upgrade is required to support a 10x faster interface
Could RME shed some light on this, especially on the second point ? Thanks in advance
2 (edited by uwekirst 2010-06-01 17:33:22)
Re: FF UC and USB3
The fireface UC is USB2 (480MBit), but it will work if you connect it to an USB3 connector, since the USB3 connector also includes an USB2 port.
There is no benefit of USB3 for audio, the bandwidth of 480MBit is enough for more than 100 channels,
/Uwe
Re: FF UC and USB3
/Uwe
Would there be any issues using a FFUC with a USB 3 port? Would it be better to use a USB 2 port?
Re: FF UC and USB3
As can be read in this forum the first USB 3 ports seem to make trouble with USB 2 audio.
http://www.rme-audio.de/forum/viewtopic.php?id=8312
Re: FF UC and USB3
Thanks for the quick reply, appreciate the info.
Re: FF UC and USB3
We found an minor issue with the NEC usb3 Controller.
If you want to use the NEC usb3 Controller with the Fireface UC and the current driver you should set the buffersize to 256 Sample (SS) or below for the WDM driver.
Buffersizes > 256 Sample are ASIO only at the moment.
/Uwe
7
Re: FF UC and USB3
These issues have been fixed with firmware 111. While not working in USB 3 mode the UC is now at least compatible to the Nec USB 3 chip and can be connected and operated without problems. As the incompatibility had been caused by a general 'hardware' problem in our firmware we expect it now to be compatible to other USB 3 chips as well.
