Topic: Weak analog output (less loud than should be): What's the pb?
Hi everyone,
I own a myultiface 1 + HDSP PCI since 2004.
Recently, I noticed that the output "analog 1" was delivering a weaker signal than it should.
The difference is quite noticeable.
If I route the signal to an output 3&4 or 5&6, the problem doesnot occur.
I tested everything in order to know that :
this is not acable problem (it occurs with other cables)
this is not a patch problem (it occurs with other patch points and with other cables)
it is not a source problem
This doesn't seem to be a static electricity issue either (I unplugged the multiface for more than 5 minutes, un plugged the PC too, but no change occured).
I wondered if it ever happened to one of you?
Is that a known issue?
Could something inside the box be fixed by myself? I do'nt mind opening the box, but it's going to be a big mess to unplug and replug everything, so I'd rather ask before in case this in not helpful to open the multiface.
Thanks for your experiences and advice.
Gedeon
