Topic: FF400 + FF800 Flash Update / WordClock Wierd behave/ No shared inputs
I Borrowed a FF800 to join my FF400 in order to be able to record 3 Adat Sources at the same time into my Macbook pro 10.6.3 in Logic Pro9.
My fireface driver was already installed and recognised FF800 fine. Following RME Tech support advice, i Ran a Wordclock cable from my FF400 output into FF800 WC input with termination. WC Led lighted up and drivers setting was ok making FF400 Master and FF800 Autosync with preffered Sync input the WordClock port.
So everything was ok, I opened Logic Pro 9 and in Preferences>Audio im only able to select FF400 driver or FF800, so i wasn't able to Choose Fireface Driver like i usually do in PC and get all inputs avaiable from both cards.
I Thought this could be something in the Firmware of the 800 being out-date. So i downloaded the Flash tool and ran it. i think it was 1.67 and was updated to 2.70 or something like that.
After I update Firmware on FF800 i lost the WC input in FF800, it seems it doesn't recognize FF400's WC. To test what was going on, i used the same cable in FF400 OUT into FF400 IN and WD Led was lid, i repeated this step but in FF800. FF800 WC out straight into its own WC in and WC led was lid as well, but i cant get it from FF400 WC Out into FF800 WC in... Weird hummm??
Then i opened Logic Pro and nothing improved when trying to get both FFs inputs at once... Is this due to the driver incapacity to do this?
Any Help is highly appreciated!
Best Regards,
Pedro Cruz
