Topic: Driver/Firmware Update feature request
Is there any way to include in the next Firmware update for the FF400 that the XLR jacks on the front can be ran at TRUE line level? This is really annoying that I can't run line level through these and limits the unit functionality.
Also, it would be great if you could assign Talkback functions to more than one output with a click of a button.
ie. You have a feed on Outputs 1 and 3 that are being listened by different people. You need to talk to each seperately, so you can click the button for whatever output the feed is on and talk without disturbing the others on the other feed.
Thanks for the consideration.
Re: Driver/Firmware Update feature request
1. There is no way for a firmware to change analog hardware.
2. You can do that by not using the TB feature, but by routing the Mic input to the required submix and pulling up the input fader. A multiple TB would clutter the TM surface significantly.
