Topic: Pipe audio data to external software
I've looked around a bit through the documentation and the forum and haven't found an answer to this. I am using an HDSP AES-32 and I would like to monitor the incoming 24 bit audio signals (up to 4 channels) with an external software program that I will develop for "real time" analysis and display. The type of signal processing I need to perform is not performed by the DigiCheck software. Also, it is necessary for my analysis to have the audio unmodified, so routing through the Windows kernel seems like a bad idea.
What's the best way for me to intercept the audio data? Is there an API for the driver dll that I can use to grab the audio streams? The sound card is installed at present on a Windows Xp computer, but it could be installed on Linux if that was an advantage.
Thanks,
Brian
