Topic: HDSP 9632 AES to Fireface
@ RME Support
I need a few clarifications please about the AES output pins, I have this scenario:
If one uses that AES output of the HDSP9632 into a Fireface, via a custom cable, no xlrs etc, (following the pinouts in the manual),
without toggling professional in the HDSP settings,:
-doubled output voltage will not be output without this setting correct?
-without this setting, the output will be plain spdif, a mirror of the regular spdif output, with regular spdif voltage ?
-will toggling Professional & using the SPDIF output, output the same doubled output voltage AES as via the AES pins ?
-Is there any Totalmix version that displays this info (other than the professional bit status) ?
