Topic: Does the original Multiface support ASIO Positioning Protocol?
I've been able to successfully synchronize Cubase to my ADAT Sync signal, but when I try to do the same in Wavelab, I get an error message saying that my card doesn't support ASIO Positioning Protocol.  Does anybody know if the Multiface supports APP?
Re: Does the original Multiface support ASIO Positioning Protocol?
One small hunch (but I'm not familar with ADAT Sync):  IIRC in Wavelab, you can use WDM or ASIO to talk to the RME card unlike Cubase where you select the driver in the Device Setup pane.  Make sure you are using the RME's ASIO devices in Wavelab.
Aside from that - I'm clueless :-)
2x SSL Alphalink MADI AX
Thanks for the reply.  I have ASIO selected, so that doesn't seem to be the problem.  This is strange, I think I've got ASIO Positioning Protocol to work with Reaper, but I'd still be interested to hear a definitive answer on whether or not the Multiface supports ASIO Position Protocol.
