Topic: Drivers 3.017
In first place thanks for the new drivers.
My general impression is that they are better. I haven't verified yet if the compatibility with the Windows 7 FW driver improved, but I will and then post here the results.
A new settings dialog layout, simpler and easier to understand. Better integration with Windows 7, with the drop of the interleaved setting and the complete set up using the windows settings, though it would be nice if the setting still existed. You are now supporting the room correction enhancement feature, and that's great, because I always wanted to try it.
However, you have removed one feature that was one of the most important to me, and I would like to know if you could include it again. Previously, the drivers allowed the setting of the clock rate by the software applications, which was great, but now, it only accepts connections if the software applications use the clock rate specified in the settings dialog. I believe this might be also related with the integration with Windows 7, because they have a standard set clock, but why not giving an option in the settings dialog to allow the software applications to use any sample rate? Previously this worked really good... or am I setting it wrong?
Best Regards.
