Topic: no sync/lock with either adat or wordclock out
I have the old Multiface with PCI card, Windows 7 64 bit. everythings working okay so far.
latest driver 3.085
i connect the multiface to a presonus digimax d8 via adat and i have a bnc cable as well.
strange thing is: the digimax gets the WC clock, but in the HDSP settings, it doesn't show me "locked" anymore. Also the green LED isn't on. Same if I try to snyc via ADAT cable.
The sound is okay, digimax is locked, actually everything is working, so I guess it IS locked, but why do the HDSP Settings not get it???
This worked earlier...
Re: no sync/lock with either adat or wordclock out
What is your setting for SPDIF In on the RME settings app? Are you using 2 ADAT cables for In/Out?
Is the Digimax connected to the MF's inputs or outputs? The HDSP settings only show the input status...
4 (edited by oltaran 2010-08-24 16:25:53)
Thank you for the very quick responses.
Jeff, I don't use SPDIF at all, only ADAT.
hmmm... so the sync check is only for input?
I also have a (sorry) Behringer ADA 8000. I sync it via wordclock, rme being master. ADA8000 is "locked"
if I then connect the ADA8000 ADAT out to MF ADAT input I get the "Adat synced" message, but Wordclock remains "no lock". If you say, that's allright, then I'm happy - I thought I used to see the "Wordclock synced" message, but maybe my memory is wrong.
Another question: What's the difference between Wordclock single speed or not single speed. Should I switch it on or off?
And one more question: Is there a difference between "synced" and "locked"?
