Topic: Clarification on incorrect level meters when DC and TotalMix parallel
Hi!
The manual doesn't explain much what incorrect level meter values mean when you open DC and TotalMix open parallel. For example: you record with the Global Record a concert and also make some monitoring with TotalMix it is good to know what happens inside. Are their different peak levels measured? Is the analysed data coming from the card "splited" between the two programs so the knows of sample 1, 2, 3 and then the other gets the information of sample value 4, 5 and six? What happens when you clip the inputs? Doesn't show any of the programs the clipping happened? What is the possible incorrectnes?
With best regards
El Duderino
