Topic: Skipping audio using FF-400 in Windows 7
Apologies if this problem was posted already and I didn't look properly.
On my audio workstation the sound is skipping during playback and recordings are skipping, for example when I am streaming audio to the radiostation I play at (DJ turntable setup -> FF -> Streaming software)
The simplest situation is when I use for example Winamp to play back music. When I start the music, all is well. The sound will play back just fine, until I start doing even the slightest thing. For example opening a webbrowser and navigating to a website, scrolling through the site, but also when I for example do some I/O such as copying files. The same thing happens when I'm recording and the skips are audible in the recording.
This is a fairly powerful workstation, built with a Gigabyte GA-EX38-DS4 motherboard, 4GB DDR2 RAM, 2x WD Caviar Black 500GB's in RAID1, Intel C2D E8400 and an NVidia 9600GT video card. The OS is a genuine Windows 7 x64 installation.
So far I have tested with and without the virusscanner active (Windows Security Essentials), I have swapped the memory with 2GB from a perfectly operational workstation, I have replaced the processor with a working E7400 to no avail. The same problem applies and I cannot really say if it is any better or worse with the swapped hardware.
Playing back audio from another computer using for example the optical link to the FF is no problem at all. It will never skip.
I would reinstall Windows 7 but this is the last resort because it takes a lot of time and I certainly am not looking forward to calling Microsoft to manually reactivate the key.
I have used the sound card with this hardware before and the only thing I can think of is that either there is a problem with the motherboard or the problem is Windows 7 itself. It is the latter I am seeking confirmation for and I'm hoping that either someone has had the same issues or that people have some suggestions for me to try.
Thanks in advance!
