Topic: Multiface 2 issues
Question -1
On my PCIe card is says HDSPe PCI rev 1.2
Is it supposed to be higher than 1.9 ?
Question -2
I have a GIGABYTE GA-EX58-UD5
In my manual it says - Due to a hardware limitation, the PCIEX1_1 slot can only accommodate a shorter PCI Epress x1 expansion card.
For a longer expansion card, use other expansion slots.
What is the best slot for to use ?
The reason why i'm asking these questions is due to the fact, i have had issues with audio on Cubase and Ableton and everything i've tried.
The problem - Everytime i record my Korg M3 or record a Virtual Instrument to AUDIO i have a problem with pressing Stop/Start.
Everytime i press Stop/Start anywhere on a section of Audio i get a click / pop. I have changed to latency to the highest settings, which does not resolve the issue.
I'm going to post a link below to a Cubase thread, were some guy is having exactly the same problem as me, and he explains it better than i will, also he has an MP3 to let you hear the problem. The problem you hear is exactly what i hear when i press stop and start ( The clicks are louder on Kicks and bass guitars and lower end instruments )
( Let me just remind you, that this is only on Audio, NOT Midi )
http://www.cubase.net/phpbb2/viewtopic. … highlight=
And let me just say that it has nothing to do with bad edits or crossfading!
Thanks for your time.
