Topic: HDSP 9632 - when using AES and optional breakout, 75 ohm, or 110 ohm?
Does the HDSP 9632 operate at 75 ohms, or 110 ohms when running AES with the optional breakout cable (BO968)?  I'm assuming it should be standard 110 ohm per the AES spec?
Thanks,
Todd
https://www.noiseradiationstudios.com
Re: HDSP 9632 - when using AES and optional breakout, 75 ohm, or 110 ohm?
110. The SPDIF port is separately handled inside.
3 (edited by Todd Loomis 2010-09-14 04:39:14)
Excellent...  Thanks!
