1 (edited by milos 2010-09-28 21:01:34)
Topic: HDSP9652 + HDSPe MADI in the same box
Hi
    would anyone know is it possible to run those two cards on one computer, at the same time, driving various xtrnal
AD-DAs? I need MADI and AES only, but have 9652 already, and MADI card has no AES (I'm about to order HDSPe MADI). As far as I can see the driver is the same, yet...
Thank you
Re: HDSP9652 + HDSPe MADI in the same box
Yes, no problem. You just have to sync the two cards.
Thank you for the fast reply:-) Yes I'll sync the whole rig by WC. Doesn't matter one card is PCI and another PCIe?
Or is there any advantegs to get PCI MADI card?
Doesn't matter smile
Thank you very much
Sorry, the last Q:
are both cards going to use one total mix-er (all i/o madi-adat-etc, on one mixer screen)?
Thank you
Sorry, no. You will have a separate mixer for each card. You can switch between these with the Unit # buttons, or open both at the same time.
Good enough.
Thank you
Oh how I wish the MADI cards had a pair of SPDIF/AES I/O and Loopback wink  Apparently all of the FPGA Horsepower is tied up with the 64 Channels of MADI I/O...
Your setup should work fine :-)
cool
2x SSL Alphalink MADI AX
