Topic: Multiple Digi96/8 PAD and PST
I have an intallation problem with my lastest Digi96/8. Since the last months I was running with 1 Digi96/8 PAD and 2 Digi96/8 PST without problem. Last week I bought a fourth one (PAD broadcast) and here comes the problem. When I installed it everything seemed ok. Windows intalled it and it was seen by windows and the RME control panel software. But I noticed that windows disabled one of the card ? And then I encounted some power off problem... Windows log out and shut down one screen monitor but stop there and never powers off the computer itself. I have to hold the power switch to turn it off. When I reboot, windows boot normally as well. I tested each card individually and they're all ok. As soon as I put a fourth one, one becomes disable in windows and my Cakewalk Sonar 3 & 5 don't see any card at all. If I remove one card, everything comes back to normal. Is it a windows or computer limitation, power supply ?
Pentium Intel P4 2.4
Windows XP
1.5 gig ram
4 RME Digi96/8 (PCI) driver 2.11 (2 PAD & 2 PST)
1 Multi I/O format / 2 X firewire port, 4 X USB 2.0 port (PCI)
1 ATI dual video card (AGP)
Power supply 450w
Thanks to all of you...
Re: Multiple Digi96/8 PAD and PST
The driver only supports up to three cards, sorry.
Apart from the driver support the main problem is the memory space assigned to each card. This gave problems even when using 'only' 3 Hammerfall cards (DIGI9652) under Windows on some systems. This problem is (of course) no longer found in newer cards (the hardware, not the driver) which use a much more sophisticated memory handling.
