Topic: 2HDSP9652 cards adat2 on both wont sync
I have 2 HDSP9652 cards in a XP3 system. 3ADA's Card1 set as master card 2 internal sync with spdif. 1st ADA set to master,2 and 3 set to slave. card1 shows adat1 sync,adat2 not locked,adat3 sync. when i switch ada 1 to card2 adat1 shows sync, adat2 shows not locked. I seem to be missing something in my setup but not sure what?
Thanks for any help
keasy
Re: 2HDSP9652 cards adat2 on both wont sync
Only one device in the setup can be master, all others must be slave.
3 (edited by keasy 2010-10-13 00:55:20)
Thanks Daniel,
That got 1st card all synced. card #2 still won't sync adat#2 any suggestions?
It shows spdif sync from internal connection from card #1 sync out to card #2 cd-in.
Thank you
keasy
I don'T know what exactly ADA means, but if you have 6 AD/DA converters they all have to be set to slave, means to sync to their ADAT input, IF you have set card 1 to master and card 2 to slave to card 1 via internal SPDIF.
