Topic: fireface400: driver 3.x suited for win xp?
hi there,
i'm running win xp sp 3 and my fireface 400 with the RME driver 2.9992. i noticed that the 3.X drivers where oficially recommended for all windows versions at the beginning, but in the meantime they are labeled 'win 7' only... now i'm wondering: should i try the latest 3.x driver with my xp-DAW or should i stick to 2.9992?
i'm asking because i have some problems with my freshly set up DAW (when i run a particular project in cubase 5 the asio-performance meter shows over 80%, while my CPU-usage meter shows 40%...) i have set-up my system following the usual tweak-recommendations (i used the ones from 'sound on sound' magazine); i'm pretty sure i've done everything right in the setup of the system. i don't have any IRQ-conflicts with the IEEE 1394 controller. at the moment i'm looking at to possible problem sources:
- the ASUS-mainboard uses an AGERE-chipset --> possible solution: using an PCI-firewire card
- using a different RME driver
or am i missing something?
best,
tomas
p.s. i use a intel quadcore (@2.66Ghz) CPU and 3 GB RAM
