Topic: UFX has errors with USB, but none with FireWire
I own two computers:
* Win7, i7 Quadcore 3GHz, Asus P6T SE, 12GB, 256GB SSD
* WinXP, Laptop, Pentium M 1,8GHz, Dell Precision M60
both installed with newest UFX drivers (USB: 0.961, FW: 3.031, firmware: 338_107_332
When I connect the UFX via firewire, I can use super low buffer settings and can record 28 tracks with 44/24 without any issues ON BOTH COMPUTERS!!!! (and so does my old FF800... always worked nicely on both systems...)
when I try the same via USB, both systems show errors (in RME driver window), and lost asio buffers. Laptop is worse than new PC, of course.
No, I dont use any USB Hub inbetween. Yes, I have tried different USB ports on the systems.
No, there are no other applications running. Yes, I have disabled all WLAN/LAN and other stupid services not needed.
For recording, I use Samplitude11 Pro, but also WinAmp playback crackles!
any ideas??? what else can I do?
greets,
Mike
