MC wrote:Sorry, but we heared this statement too often and it turned out to be wrong too often. Please give me the exact numbers.
No worries, Driver 2.76 with Firmware version 25, OSX 10.5.8, here's some more info.
Model Name: Mac Pro
Model Identifier: MacPro3,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.8 GHz
Number Of Processors: 2
Total Number Of Cores: 8
L2 Cache (per processor): 12 MB
Memory: 8 GB
Bus Speed: 1.6 GHz
Also, when i do change the sample rate the change is shown in the HDSPe settings program as well as the Alphalink but there is no audio output from the HDSPe. The HDSPe settings are (when it is not working):
56ch mode, 48k Frame, MADI Optical In, Single Speed enabled, Clock Mode: Master, Pref Sync Ref: WC, Sync check says no lock, MADI Sync, TCO No Lock, Sync In No Lock, Auto Sync Reference: Input Madi, Freq. 48k
When it does work SyncCheck says no lock w/ wordclock and Sync with MADI
It is also intermittent, sometimes i can go from 44.1k to 48k and it will work but then i go back and it doesn't and vice versa
