Topic: DIGI96/8 PAD Internal connector
I'd like to avoid using adaptator cable (D-type connector) and pick up SPDIF signal directly from the card.
What kind of 10 pins "appropriate connector" have I to use ?
The optional jumpers (not fitted, not
supplied) next to the D-type connector
allow an internal cabling, for example when
the XLR input and output jacks shall be
build into the PC housing, so that the
supplied cable adapter is no longer needed.
When using a 10 wire computer flat
cable with the appropriate connector the
connection between XLR jacks and card
will be removable.
Thanks !
