1 (edited by studioton 2010-11-16 19:41:24)
Topic: MIDI 1 UFX problem
Hi, i have a problem with midi 1 from UFX .. i have connected my midi keyboard to MIDI 1, but there is no signal, there is no LED light  .. but when i connected same to MIDI 2, everything works fine.. so, something is wrong with MIDI 1 port from back side ... is this some hardware problem or there is some soft settings to enable midi 1 port? What to do? Thanks
www.studioton.net
2 (edited by studioton 2010-11-17 00:34:25)
Re: MIDI 1 UFX problem
is it possible to be a problem with the driver because i was reading that the MIDI ports are added to the system by the driver? i hope so smile
www.studioton.net
3
Unfortunately that is a hardware problem.
4 (edited by studioton 2010-11-17 01:48:10)
Ohh.. What is now next step? I was buy in justmusic.. How long can take repair .. I must to work, my old ff800 is sold .. Oh, matthias, do you have an idea what can be problem inside, can i open and Fix it?
www.studioton.net
If you have work to do, you could use an inexpensive USB MIDI device until you find the time to send the UFX in...
It's not necessary,because midi2 port is working well, i will do something in the near future.. Thanks for support anyway..
www.studioton.net
