Topic: Multiface (I) with PCEe (laptop) FW type cable problem
I really would like to have some info from RME about the firewire type of cable requirements.
I had constant never ending issues with the bright shining HOST ERROR indicator. When I noticed that it would go away when I change firewire cables I started to wonder if there's a resistance spec from RME that most firewire cables actually don't respect. I had a cable that works, I put a sticky tape on it... only to discover that when I moved to another country that it didn't work any longer = (this raises a power supply question but never mind, we talk about that another time) bright shining non blinking HOST ERROR. Now I took the shortest (hence lowest resistance) firewire cable that I have, a Metric Halo 30cm short cable that they ship with their interface. Miracle: My Multiface works again. Unfortunately I need that short cable for my Metric Halo interface on the Mac when I'm doing large scale recordings at the same time with the Multiface on a PC...
Any word on a firewire type of cable that works with the PCI Express card? If RME sells one I would even buy it from them...
Any good word is appreciated :-)
Jurgen
