Topic: Digiface output channels problems
Hello!
I'm running 64Studio Linux.  I just switched from a PCI + Multiface, to a PCI + Digiface using my same PCI card.
I'm running 8 channels into the Digiface via ADAT 1 and 2 IN, and 8 channels out via ADAT 1 and 2 OUT. 88.2 kHz sampling rate.
My Multiface worked fine, however, my Digiface is not mapping the audio from the "Playback" section of the HDSP mixer to the "Output" section properly. Playback channel 1 doesn't show up at all in the output, and playback channel 2 ends up in output channel 1!?!
The 8 channels of audio input to the Digiface are fine -- playback section of the HDSP mixer shows all 8 channels I want to output fine -- but the final output is screwed up.
Help!  What is going on?
Thanks!
