1 (edited by dan98 2010-11-25 19:00:18)
Topic: Babyface question, using ASIO drivers with Sequoia
Hi all,
Apologies if this is either completely obvious or totally obscure question. I come from Protools world which works a little differently
When using the Babyface in an application with ASIO drivers (for example Sequoia), is it possible to address the digital AND analogue outputs independantly  ?
In other words could I have this facility:
Mixer channel 1 Output > Babyface SPDIF Optical Output > Outboard D/A Convertor > Outboard Compressor
Outboard Compressor > Babyface XLR Analogue Input > Mixer Channel 2 Input
Mixer Channel 2 Output > Master Fader > Babyface XLR Analogue Output > Studio Monitors
As you can see I wish to use the Babyface and record my outboard equipment, while also controlling my studio monitors.
OR as an alternative:
Would the Babyface work with WDM driver, so that my PC internal optical output can be accessed simultaneously but independantly?
Yours, confused smile
DG
Re: Babyface question, using ASIO drivers with Sequoia
Sure, this should work fine. Just set it up in Sequoia so Ch 1 is sent to SPDIF out and Ch 2 is sent to Stereo Master.
Jeff beat me by a minute... My internet connection is a bit slow...
Fantastic !!
Thanks for the quick replies.
So now i hunt for a good D/A.
DG.
