Topic: AEB-O boards - running two off the same power supply cable?
I have one AEB-O board powered from the supplied cable.  This cable has two of the smaller connectors that connect to the boards.  Can I connect a 2nd AEB board with the 2nd smaller connector? Both boards powered with the same cable?
tx
Re: AEB-O boards - running two off the same power supply cable?
Yes.
