Topic: Multiface I input distortion issue
I have a RME Multiface I that I haven't powered on for a few months and today when I did, I am getting strange distortion on all 8 analog inputs. I am recording at -20db  with no clipping on input and have tested two synths and confirmed their output is fine. Some inputs are +4 others -10 but no difference between the distortion on either. The recorded material is distorted so I don't suspect the audio outputs. I have uploaded a small audio snippet for anyone interested in downloading. You can see within an audio editor the waveform is sort of clipped but only on the negative(?) voltage.
Link to example audio file
Full System:
- RME Multiface I
- PCIe/Expresscard (v18)
- HDSPe Mixer 2.76
- MacBookPro GHz Intel Core 2 Duo
- Snow Leopard 10.6.5
Recording with:
- Logic Express & TwistedWave
I suspect it is dead but any help would be appreciated as I can't afford new hardware at the moment. sad
Scott
Re: Multiface I input distortion issue
I am having the same problem.  I had it once before and it just went away.  It has worked for a couple months and now it's doing it again.
Any one with ideas?
