hello,
I am experiencing similar problem with a FireFace400-UC on a MacBookPro with OSX 10.6.4 bought in april 2010.
Anyone found a solution ?
Rebooting either soundcard and/or computer doesn't work for me...
Here is what I experienced and sent to RME support (no response from them so far) :
//////////// mail #1
I have trouble with a RME-fireface400 UC that I bought recently (new).
I have installed the lastest drivers and did firmware update.
Soundboard is detected correctly but produces awfull noisy/crunchy sound, somehow as if sample rates or clock would not match, plus some ~8Hz crunchy beating frequency.
I tried with the following software, always getting the same dirty result :
- Ableton Live
- Cycling74' Max5
- Audacity
- Quicktime / iTunes
Here are my system information :
- MaxBookPro 2.8Ghz Intel Core 2 Duo
- Memory : 4Go 1067 MHz DDR3
- OSX 10.6.5
//////////// mail #2
To give you a more precise idea of what my problem *sounds like*, here is a 8s audio example of what Igor Stravinsky's "Italian Suite Introduction" sounds like when played through my RME fireface 400 UC.
I searched in web-forums to find a hint on what the problem can be, but I really can't find anything wrong in my setup.
NB : I uploaded the sound on this link : Igor Stravinsky throuh Fireface UC so that forum users can listen to what the trouble sounds like...
//////////// mail #3
OK, I went back to the soundcard reseller yesterday and we ran tests for more than a hour.
- On a MacPro OSX 10.5.4 with Digidesign driver installed
First we tried to install the fireface-UC on a MacPro with OSX 10.5.4, the card was merely not recognized by the audio system.
Device was correctly showing in the USB devices in the system information panel, but not appearing in the sound configuration panel (in Preferences)
along with built-in device.
According to the tech guy in the shop, this could be due to (quote) "the presence of Digidesign driver that fuck the sytem"
So we tried on another MacPro with 0SX 10.5.4
And here, the fireface UC appeared correctly after we installed the driver and the sound was good.
So... I am happy that the hardware seems OK, but I still have the trouble on my MacBookPro, as the sound is very noisy (as I sent you an audio example in my previous email) while I play with exact same settings as we did in the reseller shop.
The only differences I can see are :
- computer is a MacBookPro, not a MacPro
- system version is OSX 10.6.5 (aka Snow Leopard), not 10.5.4 (aka Leopard)
Do you think of anything else that could be wrong ?
Did you perform tests on a similar computer + system ?
Did you encounter any problem like that ?
Thanks in advance for any hint, please do help me (!!!), et do not hesitate to ask for more info if you need it.
