Topic: using fireface UC and madiface together
Hello there, i allready own a madiface to connect my laptop with my digico sd9 for recording and i want to buy a fireface UC to run a auxillary fed vst host running plugins on the same laptop. Will that work problemfree at the same time on the same laptop? ( sony vaio i5 560-8gbram)
regards, Onno de Visser
Re: using fireface UC and madiface together
The two use different ASIO drivers, so no way to run them together in an ASIO based DAW.
thanx for answering. The madiface and the fireface won't be using the same asio based daw. I record in Reaper with the madiface and want to use the fireface with Bloxpander vst host ( nothing to do with Reaper). ( creating extra effects for the live show. ) Is that still impossible/
regards Onno
No problem.
