1 (edited by MBM 2011-01-12 00:47:03)
Topic: Bohdsp9652midi
Hello, I have two cables wich MIDI "male" and I would like to connect to Fireface 400 MIDI. Is it possible with BOHDSP9652MIDI? I mean: does it accept male connections to use with it? I can´t see connections in photos in Internet, so I would need somebody tell me about it.
My english is very bad, so I´ll try to link a photo to see what I want to connect:
http://www.google.es/imgres?imgurl=http … mp;bih=749
Thank you and best regards.
Re: Bohdsp9652midi
Yes.
Re: Bohdsp9652midi
Thank you very much.
Best regards.
Re: Bohdsp9652midi
Hello, finally I bought this cable but it doesn´t work. When I select "Fireface 400 (18B) Port 1" nothing happens. Not LED at the interface, and my computer doesn´t receive MIDI data. Of course, I´ve connected MIDI cables to it. What could be happening?
Thanks and best regards.
5
Re: Bohdsp9652midi
Exchange in and out.
Re: Bohdsp9652midi
Yes, I tried it, and also with Port 2, but it doesn´t work. I think cable is broken, or there is another possibility?
7
Re: Bohdsp9652midi
You seem to have a used unit - maybe that was the reason it got sold?
Re: Bohdsp9652midi
No, it´s a new unit, I bought it at Thomann.de
9
Re: Bohdsp9652midi
Now then - why was that cable missing? And you have warranty, so just send it in for a check.
Re: Bohdsp9652midi
Yes, I think that is what I´ll do, because I don´t find any other explanation.
11
Re: Bohdsp9652midi
Before to send it, I want to confirm: everything I must do is to connect Bohdsp9652midi to my fireface and then connect to it the MIDI cable, is it?
12
Re: Bohdsp9652midi
Yes, and then the MIDI IN LEDs start working when they get signal. Quite simple...
Re: Bohdsp9652midi
Ok, then the cable has some problem, I´ll send it to Thomann.
Thanks again and best regards. By the way, your support is always excelent, I want to congratulate you for it.
