Topic: multiple audio monitors using Totalmix help pleez
I have a small set of Yamaha monitors and larger Genelecs...how are people configuring Totalmix to switch between the two A/B? I tried to Assign the Main fader in Totalmix to An1/2 (the Genelecs) on one Snapshot memory location (1) and then Assign the An 3/4 (Yamahas) to another memory (2). I have a Separate Subwoofer hooked up to An7/8(stereo) that I ganged to the Genelecs.
The problem is that when I switch back and forth the Main fader goes to Zero and the Subwoofer fader never returns to its proper level ganged to the Mains (1).
Right now I have given up on the Main fader altogether and just monitor using the An1/2 and An3/4 stereo output faders manually with Snapshots.  What are some other solutions RME users have for setting up multiple monitors?
Re: multiple audio monitors using Totalmix help pleez
What USB drivers did you install? The latest one has a Speaker B option in TM FX.
but the Main and B do not change levels when different Snapshots are selected. This is the problem. I need for the Main fader to be down on one snapshot and the B fader to be down on another Snapshot.
Snapshots can make the B appear and disappear, but fader levels for these do not seem to be recorded as Snapshot data.
TM FX Options, Preferences (F2), uncheck 'Do not load Main volume/balance'.
