Topic: Fireface 400 Driver?
Hi All!
I purchased the Fireface 400 in June 2007 and the Driver CD is dated 07/2006. The bottom of the Fireface has a bar code with a number, if that helps.
I would like to install the Fireface 400 driver on the new MacBook Pro I purchased this summer (OS X 10.6.5, 2.66 GHz Intel Core 2 Duo, 8 GB 1067 MHz DDR3). What driver should I download from the RME website? Am I running firmware 1.7?
Thanks a bunch!
rJ
Re: Fireface 400 Driver?
you'll find drivers here: http://www.rme-audio.de/drivers_fireface
The latest driver is 2.89. You will probably need to update firmware. Download the updater and run it, it will tell you.
Excelent, thanks a lot!
