Topic: output question
hy guys,
I have a question concerning usage of outboard equipment, in this case a lexicon lxp-1 reverb unit.
I would like to know if it is possible to send a stereo signal from my daw to the lexicon using just one physical output? (since it is balanced i thought that i can instead of two outputs use just one output with a stereo jack cable (y cable- which is at one end stereo jack and on the other two ends are two rca plugs since the lexicon was modified and has phono inputs)
I ask this because i want to know if i should make a two y-cables or four normal ones,
kind regard,
matan
Re: output question
nobody? sad
Re: output question
(you did not mention what rme product you have...)
but anyways: balanced IS NOT stereo... never was and never will be.
use four cables!
best,
laex
DC rules!
Re: output question
fireface 800, sorry smile
Thanks for the reply,
kind regards,
Matan
