Topic: Sample rate after standby (44100 vs. 48000 kHz)
I've actually had this problem since many years ago, with other RME products and other manufacturer's audio cards as well. I have RME HDSPe AIO and this is what happens:
I watch some YouTube for example and then put my PC on standby. After resuming, all audio is played with lower pitch than it should. So probably 48000 kHz is played back erroneusly at 44100 kHz. So speech in YouTube is in low pitch voice and so on. If I just open Hammerfall DSP Settings and press Buffer Size for example, it immediately refreshes and the pitch is back to normal.
How to fix this problem permanently? Note that there was no DAW or anything special loaded in the background, just some very basic Windows usage.
