Topic: Micstasy Auto-set questions.
Auto-set is a mastercpiece function, but  the user manual is not so clear.
Why auto-set is not available for ch.8? In my Micstasy the blue led (auto-set led) is not turn on.
How to define a "group" in the downlink function? I want to create two group of 4 channels each, but I don't understand how to distinguish them.
Thanks in adavance.
Re: Micstasy Auto-set questions.
The manual has two small errors in chapter 11.9 which might have confused you.
> Available settings: Channel 1 up to 7 via Select key
As becomes clear from the description in the text it should have said 'channel 2 up to 8'. In he same way 'the eight Select buttons are used for configuration' is not correct (only 7).
That said please use our Windows / Mac software MIDI Remote. It gives a better overview and has an extra button per channel to activate AS Downlink. It also allows you to verify that the blue LED of channel 8 is broken or not.
