Topic: totalmixFX odd behaviour
i am trying to figure out some oddities in totalmixFX's behaviour.
there are a couple of issues, i'll start by describing one, hopefully this is related to the other issues and solving it will solve all of them.
i am using a multiface ii, and the 4.04 driver, on a win7 x64 machine.
the issue i am encountering (among other), is that the level of the signal played through a certain channel sometimes does not reflect the settings of the respective fader. maybe it's an error on my part, please feel free to englighten.
here is a screenshot showing one such case:
the 'main' channel is showing signal running through it (this is linked to my headphone out btw.). despite the fader being at minus infinity position. the signal indeed goes through to the headphones. it is not until i manually touch the fader that it resets the signal gain to the correct value...
sometimes (this sounds rather crazy), shuffling through tracks in winamp will randomly turn up this 'main' channel's fader's volume, previously manually set to minus infinity. i checked that totalmixFX is set to not be controlled by MIDI messages just in case there were some rogue virtual MIDI messages running in the system...
