1 (edited by mr. anxiety 2015-05-26 01:01:57)
Topic: (2) Hdsp 9652e Cards in PC - Word Clock Termination issue
I have (2) HDSP 9652 e cards installed in my PC, W7, Cubase 7.5.3
RME driver 4.04
I clock from a Big Ben.
I have WC BNC cables in to Card 1 from Big Ben, cable out from WC Card 1to WC in Card 2.
The jumper on daughter card of Card 1 is not set to terminate.
The jumper on daughter card of Card 2 is set to terminate.
I have green light status on both cards.
I have WC selected for both cards in the DSP app and a WC lock in SyncCheck.
I do not have a green LED Lit for WC termination on the Big Ben. On my 5 other slave PCs with RME cards, I have a green light
Thoughts?
Nuendo 3  Dual Xenon 2.66  w/ HDSP 9652  2.94   + (2) Uad-1 Cards ver 4.9.0
Re: (2) Hdsp 9652e Cards in PC - Word Clock Termination issue
The input is not terminated. WC out is a newly generated word clock signal, so termination at card 2 does not influence input card 1 at all.
Thanks for your reply.
Is it possible for you to give me the correct way to have this set-up so I can have a successful termination back to my Big Ben?
I appreciate your help in this matter.
Thanks,
Mr. A
Simply push the switch for termination on input 1 - that's it. The rest stays as it is.
