Topic: No track control on TotalMix FX 1.12
Recently TotalMix FX started acting strange. From the interface, none of the track controls will respond (level, pan, mute, solo...) for all channels (inputs and outputs). I checked the preferences and the UI is not locked.
However, playback through the MADIface works fine, just no control whatsoever on the channels.
I run TotalMix FX 1.12 on 64-bit Windows 7 Enterprise SP1 with a MADIface USB.
Any idea what could be going on and how to fix it?
Thank you so much for your help!!
Re: No track control on TotalMix FX 1.12
Activate TM FX in the driver's Settings dialog.
Well, that was simple... Thanks very much!
