Topic: Loopback pre-fader?
I'm trying to send out my Main mix to another program using "loopback" but with the UFX it seems to be pre-fader, that is adjusting the main fader does nothing to the software send (although nit looks normal on the main fader vu). Is there a setting I'm missing?
Re: Loopback pre-fader?
This is the right way to work. Otherwise you would ruin your recording by changing volume all the time.
I guess if you're only using loopback to record. I use it to send the Main mix to a room correction plugin, that way I can switch cue sends to the Main output with Room correction engaged. I'll have to find a workaround now. I'm sure this post fader in previous versions...
That might have been the case (as bug). The workaround includes a simple cable loopback with whatever connection is free - SPDIF, ADAT, AES, even analog...
