Alright, so now I have used the Latency Monitor.
And the figures are far from fine.
The first minute or so it showed all green, except the bottom one. But after 2 minutes the numbers went up...
http://imgur.com/kwGpYjE
And here is the report in text form:
_________________________________________________________________________________________________________
CONCLUSION
Your system seems to be having difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:08:00 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: BEAST
OS version: Windows 8 , 6.2, build: 9200 (x64)
Hardware: W150ER , CLEVO CO.
CPU: GenuineIntel Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
Logical processors: 4
Processor groups: 1
RAM: 16274 MB total
CPU SPEED
Reported CPU speed: 2494 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 339,918502
Average measured interrupt to process latency (µs): 5,353798
Highest measured interrupt to DPC latency (µs): 337,455324
Average measured interrupt to DPC latency (µs): 1,100948
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 81,187650
Driver with highest ISR routine execution time: ACPI.sys - ACPI-drivrutin för NT, Microsoft Corporation
Highest reported total ISR routine time (%): 0,000743
Driver with highest ISR total time: Wdf01000.sys - Kernellägesdrivrutin för Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0,00170
ISR count (execution time <250 µs): 6542
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 1442,667602
Driver with highest DPC routine execution time: ACPI.sys - ACPI-drivrutin för NT, Microsoft Corporation
Highest reported total DPC routine time (%): 0,032259
Driver with highest DPC total execution time: ntoskrnl.exe - NT Kernel & System, Microsoft Corporation
Total time spent in DPCs (%) 0,123969
DPC count (execution time <250 µs): 427372
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 2
DPC count (execution time 1000-1999 µs): 3
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: svchost.exe
Total number of hard pagefaults 37936
Hard pagefault count of hardest hit process: 28722
Highest hard pagefault resolution time (µs): 1941652,180834
Total time spent in hard pagefaults (%): 2,471991
Number of processes hit: 20
PER CPU DATA
CPU 0 Interrupt cycle time (s): 2,277267
CPU 0 ISR highest execution time (µs): 81,187650
CPU 0 ISR total execution time (s): 0,025770
CPU 0 ISR count: 4281
CPU 0 DPC highest execution time (µs): 1442,667602
CPU 0 DPC total execution time (s): 0,879226
CPU 0 DPC count: 237457
CPU 1 Interrupt cycle time (s): 1,606514
CPU 1 ISR highest execution time (µs): 9,559743
CPU 1 ISR total execution time (s): 0,006929
CPU 1 ISR count: 2259
CPU 1 DPC highest execution time (µs): 99,782277
CPU 1 DPC total execution time (s): 0,202004
CPU 1 DPC count: 24063
CPU 2 Interrupt cycle time (s): 1,977440
CPU 2 ISR highest execution time (µs): 3,899358
CPU 2 ISR total execution time (s): 0,000007
CPU 2 ISR count: 2
CPU 2 DPC highest execution time (µs): 158,431836
CPU 2 DPC total execution time (s): 0,697484
CPU 2 DPC count: 107687
CPU 3 Interrupt cycle time (s): 2,020703
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 104,799118
CPU 3 DPC total execution time (s): 0,605674
CPU 3 DPC count: 58170
