Topic: Madiface XT power connector problems
Hi all,
I have a slight problem with my XT where the locking mechanism on the power supply chassis has given in, so when you twist the connector to lock it in place, it allows you to continue spinning it around inside.
Whilst this isn't a huge problem and the unit powers fine, I am concerned that continuous spinning of the chassis over time might twist the wires on the inside and eventually break the solder. Is the connector chassis fixed inside the unit, or is it loose?
I could send it back under warranty but I'm not sure if it's a serious issue - and I can't really afford to be parted with it for 5 weeks!
Many thanks
Re: Madiface XT power connector problems
Don't worry, this is no problem. No contacts will break.
Thanks, Matthias!
