1 (edited by samurabe 2015-12-29 18:52:57)
Topic: Behringer bcf2000 and totalimix in rme ucx....again...
First post...hey everybody..
So, i was searching, even found but still does not work.
I want to use bcf2000 to control inputs and outputs mostly of this rme product.
What i did is:
1. Bcf conected with rme with two midi cable in and out.
2.in totalimix settings/midi input out and in-fireface ucx.
3.start behgringer as mackie cubase mode.
Done
Nothing happend...schould i assign some how fader and buttons or what.
Sorry guys i am kimd of beginer
Thank you.
Mac osx el capitan.
Re: Behringer bcf2000 and totalimix in rme ucx....again...
Enable MIDI Control in TM FX Options menu.
...i did of course...i did deep research, almost for sure i try everything...maybe i need to update some Bcf drivers, but almost for sure i dont need it...
Are the UCX MIDI output LEDs flashing (indicates the unit sends a remote signal)?
Are they flashing even more when moving a fader in TM FX?
Are the MIDI input LEDs flashing when you move a fader on the BCF (means remote signal received)?
5 (edited by samurabe 2016-01-03 23:36:55)
So in rme ucx are always two orange MIDI OUT flash without any change, always the same...in bcf always GREEN IN flashing...but later, dont know why, there is nothing...
So people ...any tips...? I am getting crazy, i belive i forgot about something...
7
What means 'but later...'? If the MIDI In LEDs of the UCX stay dark then the BCF is not in the right mode or not connected correctly.
8 (edited by samurabe 2016-01-06 18:17:25)
However, midi in of ucx are always dark.
When i restart bcf2000 in for sure correct mode, midi in of rme flash short ones...means receive some signal...thats all...
