Topic: Has the RME vs Cubase delay compensation issue been resolved?
I'm trying to use a hardware compressor with my mixing setup in a parallel configuration, but the delay compensation in Cubase isn't working. When I press the button to measure the delay it measures 0ms which is wrong.
Then I read this forum thread,
https://www.forum.rme-audio.de/viewtopic.php?id=12103
and it appears that Cubase doesn't communicate with RME hardware when trying to calculate delay compensation. This results in phasing of the signal which I am getting in spades.
Is there a fix for this problem?
