Topic: Issue with one signal AN 2
I have a babyface pro which was working great until recently. For some reason, I'm only see one input signal from my mic in total mix even when I press the 48V on both mono channels.
Also on the babyface the signal is only  on the left side although I hear in both headphones pretty good. Please help ! smile
Re: Issue with one signal AN 2
You have single mic? If so you just need 48v on the one input channel.
Post a screen shot of your TM window as it will help to see what is going on.
