Topic: UFX+ and 1-2 XTC - case / max temperature
I read in the UFX+ and XTC manual, that the RME devices may be operated up to 50°C.
I have the following 2 RU rack, with 23cm depth:
https://www.thomann.de/de/thon_rack_2he … ompact.htm
- on top: UFX+
- below: XTC
Between UFX+ and top of the case
and between XTC and UFX+ I kept most space between the devices so that air can flow a little.
Temperature is currently at 40.6°C, is this ok and tolerable ?!
Later I plan to expand my setup: UFX+ and 2 XTC in this 3 RU compact rack:
https://www.thomann.de/de/thon_3he_compact_rack.htm
What do you think, is this doable 3 devices in 3 RU compact rack ?
Or do I need to take a 4 RU rack to have the possibility for more space between the 3 RME devices ? Like this here:
https://www.thomann.de/de/thon_rack_4he … ompact.htm
