Topic: UFX+ & Phones
I suppose I could use the phone outputs 9-12 on the UFX+ also as balanced outputs for balanced phones or line-out? I just invert the phase of channel 10 or 12, respectively.
Thanks for help, insights and explanations!
Cheers!
P.S. UFX+ is awesome!
Re: UFX+ & Phones
according to the handbook these seem to be unsymmetric outputs only.
DA - Stereo Monitor Output Phones (9-12)
As DA, but:
  Output: 2 x 6.3 mm TRS stereo jack, unbalanced
  Maximum output level at 0 dBFS, High: +19 dBu
  Maximum output level at 0 dBFS, Low: +2 dBV
  Output impedance: 2 Ohm
  Max power per channel @ 32 Ohm l
oad, 0.1% THD: 210 mW (2.6 Vrm
s, +10.5 dBu)
3
Re: UFX+ & Phones
Correct. Provided you feed (means route) the correct signals to the outputs. Left channel to channel 9/10, right channel to 11/12, and all output levels identical. Please note that such a routing can only be done in TM FX if the phones outputs are NOT in the control room section, because they have to be switched to mono / single channel mode to be able to route as required.
Re: UFX+ & Phones
Interesting, sorry, I didn't unterstand your demand.
