Topic: change HDSP 9632 to what ?
I have HDSP 9632 for years, with extension board AO4S-192 AIO to have 6 analog outputs to a 5.1 monitors system (5 x Yamaha HS50M + 1 Yamaha HS10W). My only use is to compose music with Cubase and many (orchestral) VST instruments (mainly VSL and Kontakt) in MIR. In a PC Windows.
I'm totally happy with it, but I have to change my CPU, so my motherboard. And new motherboards don't have PCI slots anymore (at least the ones I want, in the X99 series, probably the Asus X99-A II).
So I read many forums, including this one. I know about the PCIe to PCI adapter trick, with a PCI extension cable in order to put the 9632 in an other slot, but I saw that it's not a reliable solution, many people having problems (like the analog outputs mute), actually I never saw a testimony of a working adapter for the 9632.
Question 1 : does a PCIe to PCI adapter really works with HDSP 9632 ?
Another solution would be to change to the HDSPe AIO, which is the exact copy of the 9632, but with a PCIe connection.
But sorry, it really upsets me to spend so many money just to have the exact same thing, in order to adapt myself to the mess of motherboards manufacturers.
So, with the same amount of money or a little more, I could get a used Fireface or Multiface. I would have additionnal features like the possibility to record some things with microphones, on my homestudio or elsewhere thanks to the portability (USB or Firewire) of the card. But it's probably only a dream, since my home studio is not meant to record anything in a proper way, and anyway the probability that I will need to record something one day in the future is weak. But who knows ?
Question 2 : if I don't use recording features, is there an advantage to switch from HDSP 9632 / HDSPe AIO to a Fireface or Multiface ?
I fear the only advantages would be to have a volume knob, a nice look and less cables behind my PC...
I read that the latency in external card would be more or less the same (at least with RME cards).
Question 3 : if I choose an external card, is it really ok through a Firewire extension card (with Texas Instruments chip, as I read) ?
Question 4 : another advice ?
Sorry for this long post and all these questions !
Any help would be very very much appreciated.
Thanks,
Matthieu
