Topic: AES Input....anything special?
Hi Guys,
Just been trying to get signal out of the bog standard AES out on the back of my YAMAHA O2R console to talk to my RME UFX Fireface. I have just connected normal mic cable to the XLRs and get nothing at the RME. I have done the same with the O2R's 'D1' AES tape return and it's worked fine, so I don't think the cable is a problem. The O2R is clocking to the RME via the AES D1 return, so I'm at a loss as to what could be wrong (other than the obvious....the AES out on the desk doesn't work!). Is there a setting you have to select on the RME for the AES to be seen?
Any thoughts?
Thanks,
Al
Re: AES Input....anything special?
Don't worry....I found it. It's in the Control Panel. The default setting is 'AES' input is set to ADAT 2. Simply change it back to AES and the light comes on the unit showing it is locked to the Yamaha O2R.
