Topic: main output level RESETTING after recalling preset
hello
i have a preset called DEFAULT with all my routing, but most important - with MAIN level set to -18 dB (this is my standard monitoring level). it is saved this way.
however, when i select any other preset and the come back to DEFAULT preset, the MAIN level is always reset to 0dB, which is way too loud for my monitors.
yes, i know, i can either grab the fader and set it back to -18 dB, or click RECALL everytime after recalling the DEFAULT preset.
but if i accidentally press play i will be killed with loudness and my speakers will blow.
is it possible that the preset REMEMBERS the level of MAIN output?
