Topic: problem with TotalMix
good evening everyone,
i use a HDSPe Madiface (PCIe) with a Sonnet PCIe / thunderbolt adapter to a MacBook pro (late13) with sierra 10.12.4.
Used to work fine, but recently, not sure when, TotalMix started to show 44.1KHZ in the top bar of its window, while the HDSPe settings are correctly set to 48Khz, also the audio midi set up utility shows 48Khz correctly.
the card ID is 22849427 on hardware sticker, 22849033 on HDSPe settings window. (weird??)
Driver is 4.09 and firmware 23.
i have tried totalmix FX 1.40 and 1.42, i have tried uninstall and reinstall the software, remove plist files, no good.
1)is that important?
2)can be fixed?
thanks
aris
