Topic: Enabling EQ or Low cut turns off output
Hi.  Whenever I turn on the EQ or LC on any input or output, I get no sound.  The meters still show like normal, but no sound comes out.  With no EQ enabled, everything works as normal.  This has to be something simple, but I cannot, for the life of me, figure out what is happening.
Any help would be appreciated.
Re: Enabling EQ or Low cut turns off output
What unit is that? You use the latest driver and firmware?
I'm using a Babyface (not Pro).  Firmware is version 223, driver is 1.098.  Windows 10.
Did you solve this issue? Same thing is happening to me
I don’t quite remember what I did. Except it’s entirely possible that I unplugged the Babyface, restarted my computer, then plugged it back in, and it was that dumb of a solution. Whatever I did, I remember feeling silly that I didn’t try it earlier.
I'm having this issue too. Seems like unplugging/re-plugging fix the problem BUT every time I restart my computer I need to do that again...
It's very annoying!
If it helps; Babyface usb powered, driver version 1.168, hardware revision 225, windows 10, TotalMix 1.61
